Car just died going down the road. Checked for spark ....none. Checked for fuel pressure....yes. Opened the distributor to find small amout of oil, so I figured maybe shorted internal component. Bought remanufactured distrib.....no spark. Returned distrib. Further testing....solid CEL with service connector shorted...no codes. KOEO the CEL comes on for a couple of seconds along with the fuel pump and then goes off. I bench tested the main relay...ok. I was told I had a bad ecu because of solid CEL so I bought a "known" (?) good ecu. Still no spark. New rotor, cap, wires, plugs....no spark. I checked for voltage at coil and icm...ok (I think). I checked voltage to map sensor (5vdc & 3.5vdc @signal wire) Any advice would be appreciated.
thanks,
mike
(lowly 95 civic)
thanks,
mike
(lowly 95 civic)
