My stock crx HF has just started sputtering on my way back to work from lunch. When I'm at a complete stop in neutral the engine revs fine, but when I put the thing in 1st gear and accelerate from a stop, the things sputters and if I keep the gas pedal constant (i.e. not giving it more/less gas) it will come out of that sputtering a few seconds after (2-3 seconds) and go ok after that. It does this on other gears too and under acceleration.
I took the plug wires out olf the distributor and the contacts look ok on the wires (dang it forgot to check the distributor cap side). Since I'm at work I couldn't unscrew the distributor cap itself off.
Anyone else have anything similiar to this happen? Any input/ideas? This little car has 150K and hasn't given me any problems since I've owned it months ago until today
Oh the timing belt/water pump/ were replaced months ago
Thanks!
Thanks!
