jfish360 said:
BTW has anyone bought a motor from hmotorsonline? i was wondering if this package came with the mounts and linkage
http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30002
and the whole thing cost 1499? I was planning on getting the LSD, which ecu should i get? and im going to convert to OBD1, so is that what the harness is that hasport supplies?
If you want OBD-1, buy an OBD-1 B16. They're newer, higher compression, more power, etc, and will include everything you need. To make it plug and play, I highly recommend Rywire. If you buy a "complete changeover" it will include mounts and linkages, but you won't be able to use them. You'll need to buy the Hasport mounts ($300) and you can either get the Hasport linkages ($100) or if you can weld shorten the ones they send you. HMO charges $250 to ship your engine anywhere in the lower 48, and free shipping for anything else you order at the same time. My out the door cost from HMO was $2299, which included a $50 discount for being a repeat customer. I bought my SiR front through them in March.
The swap that I would recommend (and the one I bought) is the 92-93 Integra XSi swap. It's OBD-1, 10.4:1, 170hp, and includes a cable YS1 tranny. If you want a cable LSD tranny be prepared to wait several months on a list. If you're willing to go hydro, they should have LSDs in stock, but you'll have to pay more for the mount kit ($429) and deal with the 'clutch feel' issues that nobody seems to like.
You don't have to worry about an ECU, when you buy an engine swap from HMO you'll get the proper ECU with it. Thus, if you order the engine in that link, you'll get either a PW0 or PR3 OBD-0 ECU. If you buy an OBD-1 swap, you'll get an OBD-1 ECU, etc.
