1 - 19 of 19 Posts
Hey, if somone can help me out wiht a translation, i need exact verbology on the phrase "The Butcher Block" (as in a tavern name, or something similar), how exactly would you say that in French?
THanks! :)
Discussion Starter · #4 ·
Babelfish doesn't give what i'm thinking is an accurate translation, because it does not "reverse translate" cleanly... i.e. it doesn't give us the same thing back that we put in in english... so i'm just looking for the -exact- and proper verbage :)
Discussion Starter · #6 ·
That actually translated back in Babelfish properly... however, it did with both:
le bloc des bouchers
and
les bloc des bouchers
Now.... that looks pluralised to me, so if you were trying to describe "the block of the Butcher", or rather, a restaurant called "The Butchers Block", non-pluralised, would that be the same? and whats the difference between the two phrases there? Is one masculine versus femenine, or..... well, i dunno, i'm just speculating :lol:
Atfirst when I read what he said I was asking myself the same question, but I figured he knew what he was talking about. Again he said that the previous translation was a direct word for word~ translation, and he knew right away that it was run through a translator. He also said that it doesnt translate 100%, but thats the closest he can think of. I know french in Quebec slightly different then french in Europe, maybe that has something to do with it?
-Sulk
Discussion Starter · #13 ·
I'm hoping that someone here speaks literal french, and can enlighten on this... even if i have to add another word or somethign to make it make sense.. lol.
I need something by tomorrow though... if i don't hear anything different, i think we'll go with "Les bloc des bucher". Although, the "table" version may work as well. I'll probably submit both to them.
Discussion Starter · #17 ·
Sure thing Penz....
Actually, it is not a sentance, but more of a "name"... like in this case, it is the name of a restaurant.
In english, we'd just call it "The Butchers Block"... so i guess in a sentance, you could say "I think i will have dinner at The Butchers Block tonight"
We'd just call it that, but being as it has a French atmosphere and genre, the name also needs to be in French, and requires the proper pronunciation and verbage for the use...
HEre I am, speaking french.
The butchers block would be translated as indeed "le bloc des bouchers", or if the restaurant name spells The butcher's block, it would be translated as "le bloc du boucher".
In your sentence, you would say "Je pense aller diner au Block du boucher"
1 - 19 of 19 Posts
