1 - 5 of 5 Posts
Need help I just replaced all 4 shocks and all the brakes on a 1986 card si on the front shocks there are 2 places to bolt the brake hose to which one should I use the closest to the front of the car or the one towards the cab of the car when I put the tires back on after all the work I bolted the brake hose to the bracket on the shock that’s toward the front of the car and the lead weight on the back of the tire cut the hose and I lost brakes I don’t have the brake hose on the driver side bolted in yet so I want to make sure I do it right any help would be greatly appreciated
Sounds like you did it one way, and that failed. Maybe try the other way, then?
--DD
1 - 5 of 5 Posts
