getting all heated because things were pointed out that you were not 100% correct about and you blindly got speakers from
"very large and well respect car audio specialist." - crutchfield, really? I guess buying a turbo from andysautosports because they said it would fit is a good idea too?
crutchfield gets it wrong, as often as they get it right.
also some facts, since you don't know either (if you did, then you'd know already you were wrong)
"Coaxial speakers in automobiles are 2- or 3-way loudspeakers in which the tweeter, or the tweeter and a mid-range driver, are mounted in front of the woofer, partially obscuring it. "
woofer = "Woofer is the term commonly used for a loudspeaker driver designed to produce low frequency sounds, typically from around 40 hertz up to about a kilohertz or higher. "
and, since there is a little lack of information :
Subs cover : 20Hz~60Hz
woofers cover : 60~150hz
Mid-Bass covers : 150Hz~300Hz
Mid Range Covers : 300Hz~5,000Hz
Tweeters Cover: 5,000Hz~20,000Hz
and according to you :
"Specs say "50-25Khz frequency range""
it's hard for me to read... but... 50hz-25khz, is 100-300hz in there?
I'm done with this... good luck with BSing. if you don't know something, be the bigger man and admit it.
