Sorry to jump right in with a bunch of dumb questions, but I need fresh brains (mine are shot). I have been trying to tune a B16a1 with nitrous (65 shot) but have run into some walls (figuratively speaking).
Setup:
B16a1 stock injectors/FPR/fuel rail/intake-TB
Zex Nitrous Oxide @ 65 level engages @ 5200rpm
Home Brew ram air intake (which appears to work because it was leaning me out -according to the plugs)
Hasport 4-2-1 header
2.25" exhaust
Walbro 255 fuel pump
MSD Blaster Coil
MSD cap
Accel 8MM wires
**NGK BKR7E (one step colder the OEM)
**Zex plugs (supposed to be 2 steps colder)
Distributor was replaced in 2003 w/NEW OEM unit and shows no signs of wear.
Problem/ Ignition: Timing marks jump around @ idle (I'm guessing +/- 5º or ~8º-10º sweep- from base setting). So I can't nail the timing exactly where it's supposed to be. Checked wire separation, checked cap and rotor and timing belt, all look ok. Installed MSD 6AL which made no difference. Set timming back as low as physically possible and still had detonation (black and or silver specs on plugs -viewed with 10x lighted plug inspector). **Note: With the timing advanced ~-2º I still had small black specs on plug off the bottle
Problem/ Fuel: Installed Walbro 255 intank pump. Talked to RC Engineering and they felt that even if I went to the 75 shot the stock injectors should still be fine. They said that unless there is a drivability problem, no need to have them rebuilt and that larger injectors would probably cause idle/low speed drivabililty issues.
Observations: I have a narrow band (I know -stupid) A/F gauge running off of the secondary O2 sensor. At WOT it's always is 3-5 segments in the 'rich' section. I can hear no audible pinging. A compression test shows that all cyl. pressures are within specs on the differential but my pressures are in the 90PSI range (I think 130PSI is the service limit from Honda). I have found the black/silver specs both on and off the bottle. The nitrous kicks in @5200 (or at the VTEC switchover @ WOT).
**I went a couple of steps larger on the fuel side of the nitrous nozzle which didn't seem to help that much. But then again, I was getting specs on the plugs without the spray as well.
Anyone have a thought on this?
Thanks,
Sean
Setup:
2.25" exhaust
MSD Blaster Coil
MSD cap
Accel 8MM wires
Thanks,
Sean
