When I go fill up, full tank is usually around 8 gallons. But i think when i read the spec of CRX the gas tank capacity is 10 or 11...are there reserve tank in CRX?
Makes sence, so your not stuck on the side of the road every time you run empty.Something similar can happen when the float nears the bottom of the tank. Often, the range of motion does not extend to the very bottom, so the float can reach the bottom of its travel while there is still fuel in the tank. This is why, on most cars, the needle goes below empty and eventually stops moving while there is still gas left in the tank.
