1 - 9 of 9 Posts
First how do you get the clutch off there is about 10 or so starish shaped nuts or bolts that i dont have a clue what socket it would be? then i guess i could figure how to get the flywheel off. its a b16.
Discussion Starter · #4 ·
WOW another retarded moment, i should of thought about that. a 17mm you say thats weird ive never had to use a odd number socket mm on ym crx.
ZeniceguyCRX said:
10mm 12point
back of a 10mm wrench for the clutch
17mm 12point for the flywheel
again the back of a wrence
I don't get it... back of the wrench?
To hold the assembly from moving the best thing is one of these:
It grabs the flywheel teeth and keeps it from moving, without stressing the bolts or ruining threads.
What about all the bigger suspension bolts/nuts, engine mounts, and the tranny case to engine bolts?
I would but who wants to pay 76 bucks for this? Tools arent cheap
Well you don't need the snap-on one! I'm sure someone else makes them, maybe autozone rents them out. I found the snap-on one because I know for sure they make them since that's what I use.
1 - 9 of 9 Posts
