Yep, Exedy stock replacement. If you aren't getting a new flywheel, resurface it. You will be replacing the pressue plate and throwout bearing with the clutch kit already. You might also want to do the input shaft seal/bearing, it's pretty common to do with the clutch, but it will require you to take the tranny apart.
