1 - 10 of 10 Posts
well here is the story after recking my 89 si i picked up a decent hf for cheap. at first i really missed the si but now i 'm starting to like it even the blue interior. what i really miss is the sunroof. so i'm planning on getting one(glass) is this a good idea?? if so do you guys know of a good shop in so cal by anychance? any comments welcomed thanks
capuchin
Is it a good idea?
Yes in the sense that the glassroof is ill
No in the sense if you have a problem with the wrong person, or park in a bad hail storm, or park under a tree, or wreck, you may have a shattered roof, which is expensive to replace.
But I myself dont care, and have on, and when I get my next straight bodied CRX its goin on
"But I myself dont care, and have on" how you do it?? did you get one from a hatch, did you take it to a shop or what???? i'm 100% shure i'm ganna do it but not shure whats the best way to go. any comments are welcomed.
Oh I misunderstood you, I thought you meant glassroof as in the JDM glassroof, but Im guessin now you mean the glass sunroof on the hatch.
Same concept though, a little different since you cant just swap roof skins, but I'm sure you could have a body shop graft it onto your roof
Glass aftermarket sunroof?
I am guessign this is what ou are getting at / / / not that hard really. . . . .Wack out a big hole in your roof. . . This is the hardest part. .. . wacking a big hole in your roof. . . . . after you get over the chock of what you just did. . . . .just bolt her in there. . . . . you can do it yourself. . . .but it would be better to have a shop that does this all the time take care of it for you . .. .and look for a place that will warranty against leaks. . . alot of these aftermarket roofs are prone to leaking as a result of poor quality and poor installation. . .
in my opinion they take away from the look . .. . but on the other hand it is nice to have a sunroof..
Unless your talking about the glass power sunroof from the hatchbacks, they slide INSIDE the roof if I remember correctly, we don't have enough roof for that.
You could use the one from the hatch and just don't let it open all the way. No one would really know, they'd just think you only opened it part way because thats how you like it...
Which is the exact reason i would stay away from aftermarket sunroofs.
Most of the ones i have seen sooner or later leak.
Which is called a moonroof and would never fit a Crx.
As stated, not enough roof for the glass to slide into and the Crx roofline is different from the hatch obviously.
Discussion Starter · #9 ·
goCRXgo i wish i could do the jdm glassroof on my car but i have no idea where to get one i bet its not very cost efficient. i would if i could trust me i love the look.
baker are there other options?? because i really want one. or should i just look for an si??
1 - 10 of 10 Posts
