1 - 8 of 8 Posts
drip rails- the seam sealer dries out and cracks, allowing water in, usually drips down behind the seats
sunroof drain tubes- These get plugged up, and can leak at the top, or from the sunroof tray, anywhere in the passenger compartment
tail lights- the gaskets don't work as well once our cars get old, so the water will run into the spare tire area
Is the weather stripping worth replacing? Or is there a home remedy that may be worth looking into? I have heard if you go to honda for the weather stripping you are going to pay an arm and a leg.... :?:
Discussion Starter · #6 ·
Its dripping from the left attachment point for the hatch arm. I looked for the sunroof drain plug but cant find it. Anyone got a pic? Also what does the USDM have instead of the back seat my car has?
Pull out the rear hatch plastics and you can see the rubber tubes the sunroof drains through. They drain into the rear wheel wells if that helps, the tubes are 2-3 cm in diameter, translucent plastic. Instead of a seat we have a cargo container, you can sort of see it in these pictures.
If it's dripping from the hatch struts, chances are it's the washer squirter. Pull it out carefully using two credit cards, and reseal it.
1 - 8 of 8 Posts
