Sorry for late response I also work 3rd to as well so days are short, but Thanks for all the help...as for the Compression check, yes it was at TDC and I let turn for about 5-6 times, throttle wide open and nothing,...
on the way the car was running fine it stuttered a little, I let off the gas and about 5-10 secs later it just cut off( just the engine nothing else)
I had to push it out of the road and then get it towed. thank god it's light weight
As for the Rebuild I do want to do rebuild it but just need a "right now solution", as I have found there don't seem to be many in my area, that i've found... so will def ask for help when I can do it ...
And for the rebuild kit I was talking about a full/complete rebuild, the engine has just under 200k and and I'm sure the guy(s) who had it before me took everything it had to give so it despretley needs the love, but where can I get THAT kit?
ok so these are the things that I can use?
Intake
harness
dizzy
Trans
exhaust
flywheel
So would I need to get a new clutch, not too fimiliar with man trans, but def know about pullin engines mostly with eights but will and am follwing the the Haynes and Honda factory service manuals.
And to clarify, there won't be any problems with OBD?
and where do I find a write up... most of what I found is for Z6 and VTEC which I don't think I can handle just yet...but def in the near future
