I've had a heavy clutch since I got my car back in May. I posted to the resource way back when, and got some suggestions about it, but I didn't want to take the transmission out so I left it alone after replacing the cable. I have some time this weekend, so I'm going to go in there and see what's wrong, I'm guessing the throwout bearing is not greased. Should I replace it? I also want to inspect the clutch to see if I should order a new one soon. I know it takes a while and someone is going to say just get a new clutch, but I don't want to do that if I don't have to, and I have a couple friends to help and a full shop to work in, so it's not that bad.
I need to know about taking the tranny out. I read stick's how-to, and I helped my friend switch his DX tranny to an Si one in september, he has a Z6 in an EF hatch. I remember we had to pivot the motor down to get it off, but there wasn't mention of that in the how-to. Do I need to do that? The reason I'm asking is because I want to know if I will need to drain the coolant as well, if the motor moves much it will need to be disconnected at the upper hose.
It's getting really irritating having a clutch that takes most of my leg muscle to push, I was used to it, until I drove my friend's integra and found myself slamming the pedal to the floor on every shift. If I do get a new clutch, who has the best prices? I don't think I need anything crazy, it's pretty much a stock motor. I may go with a lighter flywheel, depending on what's left in my bank account after I get my suspension, I really like that ACT Prolite.
