Suggest you first figure out a budget and what you can pay for.nickps51 said:i what would you suggest for me on street/strip
With a budget of 3k, that is pretty much blown with the h22 swap with little money left for other items(whatever may pop up) or even for labor costs. I only assume since the author sounds kind of new to this and would need someone to put this in for him.ollie said:Pick up a H22 swap.I know that HMO has em for $2200 but thats cutting it close.
Why an H22? 200 hp and TORQUE! Something I feel some honda motors seriously lack.
I also know that Hasport has a new H22 swap mount kit w/a alt relocator brackets for $750.
Try and locate a complete(Engine,trans,axles,ECU) swap used.There out there. Pick up a Hasport swap kit,and read the hell out of this link.
http://www.explicitspeedperformance.net/TheEFH22AHowTo.html
GL
Good points baker, I didn't think about it like that. I'm sure you would tell him to get a ZC, which definitely should be an option for him. Rethinking it like that, I would say get either a ZC or a newer D series, like a Z6 or Y8. They will all bolt in, though the SOHC VTEC motors will be a little newer, so may be in better shape than a ZC that's been sitting in Japan for ten years.baker423 said:With a budget of 3k, that is pretty much blown with the h22 swap with little money left for other items(whatever may pop up) or even for labor costs. I only assume since the author sounds kind of new to this and would need someone to put this in for him.
So would you be putting this in yourself?
Is the car your Daily driver and would you it disrupt you if the car was laid up and torn apart for awhile.
Plus the h22 is not going to be swapped in by a rookie in a weekend.
Some more things to think about.
