1 - 4 of 4 Posts
The beater isn't starting. 1991 Civic hatch. DPFI. Took the fuel line off that goes into the big black DPFI thing, no gas. Fuel pump is not priming. Can't find the stupid fuse for the thing, is there one?
The car is a wiring nightmare. THe cig lighter stopped working, but the interior light works fine. Same time that went is when it woudn't start.
I've checked every visible fuse and none are blown.
It's getting a CEL code 16.
are you getting spark?
check this because if your not getting spark then you main relay is most likly out
you already know you not getting fuel!
so if it is the injectors i have a set of injectors for your motor ill sell them cheap!!!
1 - 4 of 4 Posts
