Ok I've got about 50 posts going around here about the $400 CRX Dx I just got. i've talked myself into picking up the motor from the previous owner as well. Here's what I have so far:
Stock 1990 CRX Dx, only mod is a K&N intake.
The swap history is:
DOHC ZC from a wrecked CRX my friend had pulled from the scrap yard. Before he got the motor out, someone had taken the oil pan and crank pulley. (not a problem, read on...)
PG7 ECU out of the same car
I'm trading rex2ner the ZC transmission for:
D series oil pan (zc or Si, either will work)
Si transmission
Si axles
ZC crank pulley
Ok, that's where I'm at so far. The misc parts I've collected or will collect so far are:
Excedy OEM D series clutch kit
5 quarts Oil + Filter
Plugs and Wires
shift linkage rebuild parts as listed in another of my threads. no since dropping a new motor and strans in on sloppy shift linkage.
What I would like input on from you guys that have tackled a swap before is what else I should look into buying before I throw it all in the hatch of the CRX and drive 6 hours to New England to do a "drop -in swap" What all parts should I have on hand, or what snags should I expect?
Si transmission
Si axles
ZC crank pulley
Plugs and Wires
