1 - 20 of 20 Posts
Discussion Starter · #6 ·
jeez so thats how they are? i thougt there was something wrong with it. its worse when i'm in bumper to bumper traffic people look at me like i'm an idot thinking "dude, this guy sucks at driving"
thanks for the info [/quote]
It's not just because of a lack of torque or power.
My B18C does it too.
Wheels want to spin at X speed. Engine runs at X Rpm. Makes it buck.
feather the clutch is one thing that works. I sometimes pull on the E-brake a little too.
That's what is happening, but the HF motor doesn't have a choice about where to spin because it doesn't have enough torque to overcome the weight of the car, so it shakes as the motor is tossed around the bay.
· Administrator
Capuchin said:
oh, i see.
so for instance if i swap a b18 to my rex will the problem go away because of the HP da b18 makes and my car being so light...correct?
I think it would be less pronounced. How long have you had the car? Experience is probably the best solution. I've driven a lot of cars, every clutch is unique, and you just adapt to it.
Screw feathering the clutch, just smoke the tires (tire) until you gain momentum! Plus tires are easier to change than cluthes!!!
Ok ok ok , its getting late and i'm still at work. I may or may not be going a little crazy today.
Discussion Starter · #18 ·
i have only had the car for a month or so. the problem is not when i get going its when i creep to a crawl when the problem starts. for example on my way home when traffic is bumper to bumper i'll be on first gear and be going about 5-15 mph the will start jerking for no aperent reason.
Could worn/torn motor torque mounts be making it worse? Perhaps the motor is hitting a resonance at slow rotational speed and causing the bucking to be so bad.
1 - 20 of 20 Posts
