Was just hoping somone might have an idea what's going on with my car's idle problems (90 DX manual). It runs fine when the engine is cool or even when it's hot, provided I don't run the AC. After some highway driving with the AC on, I get the high idle problem when I turn off the AC, but it seems ok when the AC is on. The tach runs up about 2k and surges from about 900 to 2k. Something keeps telling the EACV to stay open, because I can clamp the hose shut or unplug it and the idle drops down to where it should be, but there's still a small amount of surging going on. It seems like the problem only happens after running the AC on a really hot day. If I don't run the AC, the problem never shows up. After the car sits for a little while, I can start it up and the problem is gone.
Things I've done: Cleaned the EACV, cleaned the Intake Air Temp sensor, tested the Air Temp Sensor (within Helms specs), tested the TW (water temp) sensor (within spec), checked for air in the cooling system (bleeder shows no signs of air), reset ECU, and cleaned the TB. Everything else seems to be working correctly. I'm at a loss and any ideas would be greatly appreciated.
