This usually happens during the afternoon, but when I go to start my car after work, itll turn over and start, then a second later, itll die, then turn over but fail to start for a few minutes and then repeat the same cycle.
A few minutes later, Ill go to attempt starting it again, and itll fire right up, like the problem never happened. Im baffled as to what is causing this, is it something distributor-related? Or is it something related to the fuel pump? I kind of doubt the fuel pump or its relay being the problem, because I hear the pump running. Any ideas?
