1 - 6 of 6 Posts
Ok, I stupidly broke out my window last week, and I put my new one in a couple days ago, now I cant get this trim piece back on. The one on the front of the window.
I have all the clips still there as can be seen in the next pic.
I just can't figure it out, if anyone knows how to put it on correctly please respond, I don't feel like driving my car without it.
This peice is impossible to install properly without removing the windows. I just bought some glue adhesive(liquid nails) from the hardware store and applied it to the black plastic trim where the three notches are where it would touch the orange connectors. If I remember correctly, I had to trim the notch area so it could slide on, instead off snap on. Just press it on and hold a few seconds. Should hold it for a few years and just glue it back on.
It is not impossible to replace this piece, in fact there was just a good write up on it on hondatech the other week, but unfortunatly I cant find it. I know that if you roll your window down and remove the weatherstripping around the window, you will be able to look in and see 3 screws. They are what helps hold it in place.
For the full write up, I would recomend asking on hondatech for it. You are sure to get flamed but it will be worth your time.
Your thinking about the trim peice on the door. cbp_crx was talking about the one attached to the rear window.
1 - 6 of 6 Posts
