1 - 15 of 15 Posts
I want to take off everything I don't really need inside the engine bay and on the engine. I have already dismantled the AC system, it will be gone for good. What else can I just get rid of? I want a very clean minimilistic engine/engine bay.
coldtotouch said:
If you wanna sell that a/c system, as long as its whole, i'll take the whole thing off your hands for a fair price :D
sorry, i would have but i took off most of it in the fall. accidentally...threw away the compressor and everything. it was working too. i went to pick it up from the dumpster a few hours after and it was gone =(
any AC sensors or relays you need let me know. i'll practically give them away.
You can take out quite a bit if you don't care about a/c.... You can also remove or hide a hefty amount of vacuum lines, charcoal canister, and anyting else you don't want showing. Redo fuel lines and filter so they are hidden more, maybe even redo the brake lines a tad, relocate the battery, relocate the radiator overflow, etc... Also, tuck the wires, and clean up the engine bay... it'll be puuuuurty.
<~~~ Also likes the "looks like it doesn't have enough hooked up to run" look 8)
Get rid of the charcoal canister and purge solenoid. I remember you're going mini-me, so you won't have a vac line running to the MAP on the firewall either. On my Z6 manifold, all I have for vacuum lines are the PCV, brake booster, and fuel pressure regulator. You can remove the coolant lines I guess, but it's going to make it idle like crap when you first start it up. Here's what mine looks like, it's pretty clean:
Moving the MAP wire from the firewall to the TB isn't bad, you don't have to extend anything, but you will need to cut the harness wrap a little. The fuse box tuck is similar, no extending, depending where you want to put it.
black intakes are cool :)
looks just like mine...
charcoal canister mounts nicely under the intake manifold if the bracket is removed from the manifold.... just lenghten the lines a little...
Fuse box can be easily relocated into the cabin with a little creative soldering and time.....
battery fits nicely in that large space in the back of the CRX
there are 3 big things right there. . .
good luck to you
Chris
Discussion Starter · #9 ·
OK...
Charcoal canister is in the trash. The valve right next to it on the right is still in the car. I can throw this away right? There are two plugs running into it from the wiring harness that's still in the car (not the engine one). Do I need to hook resisters up to any of the plugs if I throw away the valve? The valve also has some vacuum lines on it.
thanks
nick
1 - 15 of 15 Posts
