I posted a question a few months back (on another forum) concerning the issue of nobody having window visors available for us USDM CRX guys with door mounted seat belts. The best answer I found was ones that fit the 88 CRX or whatever year as long as it had B-pillar seat belts, I'm pretty sure the HBs and 88 crxs use the same part number so thats what I went with. The only other versions available are JDM ones which are WAY over priced and not even as effective as cheaper Ventshade brands, so that left me wanting to solve the issue mainly because when it rains my windows fog up all to hell unless I roll my windows down of of course all that damn rain just pours right in the car and just slowly kills the interior. So I finally decided to figure out a solution and heres what I have, cheapest way I have found to run these and so far I'm the only person I've seen with them so I hope this does alot of guys well
This is pretty simple explanation/write up of how I did it. You can see the part umber I used in the first pic. 1st step is just to test fit them to see where the edge of the b-pillar door garnish is under the visor so you will know how much to cut off as this is the main problem with them fitting. The actual curve of the visor is off compared to the CRX door but it's not bad and there's plenty of adhesive to hold it in place (Test fit FIRST). The passenger side was a different length than driver side so I had to measure each individually, possibly due to having the side view mirrors mounted a little offset or something? your car may be different but I still recommend not trying to short cut by cutting them both the same amount.
All I did next was use some weather stripping I bought from home depot to cover up the small spot left after cutting out the necessary section out. This helps to keep the fit water tight, the pictures really do explain the simple process pretty well. Incase anybody's wondering how they work on the CRX after custom install? It rained STUPID hard that night and I had my windows down a few inches the entire night (6 hours of delivering pizzas) w/ no leaks what so ever, and the best part was my windows did not fog up like always since I run no AC. and of course thats the biggest reason of all that I even run these, to help keep the car dry while "defogging" the windows any time it rains really hard, otherwise or if I had AC I would probably never have messed with window visors. All in all though I do like the way it looks either way, hope this helps some of you guys out!
Here you can se the part number I used, these actually fit a 88 Civic HB perfectly, I never had a chance to test them on a 90-91 HB. I bet they fit 88 CRXs as well w/o any cutting?
