This guide is for the adjustment of the e-brake/parking brake on 88-91 CRX's. If you have a lot of slack in your e-brake lever, or your e-brake doesn't hold the car securely when you are parked on a hill, this "how to" is for you.
Tools/supplies needed:
Jack and jackstands
2 Blocks of wood (to block off the front wheels)
Flathead screw driver
12mm wrench (Gearwrench highly recommended)
Before you get started
If you just replaced the rear brakes, you should depress the brake peddle several times before carrying out this procedure. If the rear brakes aren't seated properly, the adjustment procedure will not adjust the e-brake properly.
E-brake Adjustment
First, block off the front wheels and jack up the rear of the car by the center rear tow hook. Place jackstands under the lift points on each side of the car. The front wheels must be blocked because once you lift the rear of the car off the ground, your e-brake is no longer preventing the car from rolling.
Inside the car, move the driver's side seat all the way forward and remove the rear cover panel on the e-brake console. The e-brake adjustment nut (equalizer adjusting nut) is under this cover.
Pull the e-brake lever up only one notch (one click). Tighten the adjustment nut slightly with your 12mm wrench. Check the rear wheels to see if they drag slightly when turned. Repeat the adjustment process until the rear wheels drag slightly. Release the e-brake lever and check that the rear wheels do not drag when turned. Re-adjust as necessary.
NOTE: If you fully tighten the adjustment nut and your rear wheels turn without any drag, there may be a problem with the e-brake lever mechanism (could be broken or disconnected) or the e-brake lines may be stretched and need to be replaced. It could also indicate that the e-brake arms on the rear calipers may be in the incorrect position. When in the correct position (with the e-brake completely off), the arms should be touching against a stationary pin on the caliper. If they aren't, you should be able to take up some of the slack by disassembling and reassembling this section of the caliper in order to get the arm in the correct position.
When the e-brake is properly adjusted, the rear brakes should be fully applied when the e-brake lever is pulled up between 6 - 10 clicks.
Jack and jackstands
E-brake Adjustment
