Here we go... the EG arm rest "how to". :wink:
First off you're going to need an arm rest from a EG (92-95) Civic and a CRX e-brake cover:
You're going to need to make some cuts:
When you make the cut on the arm rest make sure to leave enough material to make little angle notches
It's probably not necessary but I also notched the back of the arm rest:
On the e-brake cover you can see the cuts:
See how the rear was shortened and cut... note the mounting tabs are still intact:
Now lets put the two together... see how the little angle notches lock on the e-brake cover:
Drill some holes and use zip ties to attach them together:
Here are some photos if the clearance issues:
And one of the front:
All installed:
Sorry if I'm not super descriptive. Hopefully the pictures tell the story... if not just ask.
b
All installed:
