I've got an '90 CRX Si that I bought new and it is all stock with 100K on the odo. It's been trouble free all these years and the other day, the idle started acting up. The first thing I wanted to try was to see if it was throwing any codes. I've located the ECM window under the passenger side carpeting. When I turn the ignition to on, it flashes once. With the ignition still in the on position, it doesn't flash anymore. When I turn the ignition off, it flashes once. So my question is, is this normal? I'm thinking it flashes once just to let you know that the LED is working and then you should wait a few seconds and it will then flash to show you any real error codes that may be present. Or am I to take the original first flash as meaning it is throwing a Code "1" which is of course for oxygen content (oxygen sensor). Thanks, Charles
