I know this is an old thread. But given that it is a how-to thread, I figure it's okay to add to an old thread. Anyway, it seems to be commonly recommended to use DA Integra rear trailing arms on ED/EF Civics and CRXs for rear disc brake swaps. But from what I have found, this is not without a potential problem. Specifically, the DA trailing arm actually brings the rear wheel out toward the fender by about 3/8 to 1/2 an inch. There are admittedly many situations where this is not an issue. However, if you are using wider and/or larger diameter tires and wheels and possibly lowering your car, this change in wheel position is enough to cause SERIOUS problems with tire rubbing. Even more modest tire/wheel/suspension setups can cause rubbing with DA trailing arms if your car is more heavily loaded, especially with lots of cargo in the rear. I have to say I'm actually surprised this hasn't been brought up ONCE in this thread.
The solution to this problem is to not use DA Integra trailing arms. If you can find 1990-1991 Civic/CRX trailing arms, GREAT. Slap them on your car with rear discs and be done with it. But these can be quite rare at salvage yards. If you CAN'T find them (or if they are available, but at high cost used), pull the rear spindles off a DA Integra (by the four Torx bolts and one large nut) and swap them onto 1990-1991 Civic/CRX drum brake trailing arms. This, of course, is NOT an issue if your car is a 1990-1991 model. But 1988-1989 cars will require you get 1990-1991 trailing arms, as the brake hoses and parking brake cables don't fit properly on the older arms. Then just bolt the DA Integra rear brake hardware to the hybrid trailing arms.
