This guide is for replacing the alternator on any 88-91 CRX.
Tools Needed:
Jack and jackstands
8mm wrench or socket/ratchet
10mm wrench or socket/ratchet
12mm wrench or gear-wrench (faster)
14mm wrench and socket/ratchet
Pry bar
Hammer
First, disconnect the battery. You don't want to shock yourself or damage any of the electrical components in the car if you short out the alternator.
Remove the 12mm slider adjustment bolt that holds the alternator in place on the slider bracket. Tilt the alternator back and remove the belt. Inspect the belt for any wear or cracking. Replace if necessary. (NOTE: on cars with A/C, you will need to undo the A/C belt in order to replace the alternator belt.)
Remove the lower 14mm nut that holds the alternator to the alternator bracket. Remove the bolt (You may need to tap it lightly with a hammer to break it loose).
Usually the alternator will still be stuck/pinched in the alternator bracket. Use a pry bar between the alternator and the alternator bracket to pry it free.
Now that the alternator is free, undo the electrical connections (much easier to reach once you can move the alternator around a bit. The top power connector is held on by a 10mm nut. The large round connector on the side of the alternator can be removed by pushing in on the side clip of the connector and gently wiggling it free. Sometimes there will also be an 8mm nut and metal clip that holds the wiring harness onto the side of the alternator.
Slide the alternator out of the way along the cross member towards the passenger side of the vehicle.
Jack up the car at the mid-point of the front cross member. Place blocks under the rear wheels and jack stands under the side lift points for safety.
There are two 14mm bolts that hold the alternator bracket onto the engine block. You may need to use a normal wrench on the one that is closest to the driver's side of the vehicle. I was unable to get a socket on it. If you can't reach these bolts, you may need to remove the driver's side wheel to free up some space.
Once the bracket is removed, remove the 3 plastic screws that hold on the plastic wheel well shield at the front of the wheel well.
Pull it down out of the way and then slide the alternator out through this space. You may need to twist and turn the alternator just right to get it to fit through the space.
Reinstall the alternator in the reverse order of the steps above. The alternator bracket has a small metal bushing that pinches against the alternator when the bolt is tightened. You may need to tap this bushing back out a bit so that the new alternator will slide into the bracket.
Tighten up all the bolts except for the top slider bracket bolt and the bottom alternator nut and bolt. Slip the belt back on and make sure that it is aligned with the grooves on both the crank pulley and the alternator pulley. Use a pry bar between the alternator and the block to tilt the alternator and tighten the belt. While holding the tension, tighten the 12mm alternator slider bolt. Check to make sure the belt is tight, then tighten the lower 14mm alternator nut and bolt. Reconnect the battery.
NOTE: A belt that is too loose will squeal and may cause low voltage output. A belt that is too tight will put excess strain on the alternator pulley and could shorten your alternator's life expectancy. Tighten it until there is no slack in the belt, and then give it a little push beyond that. If it squeals, tighten it a little more.
You're finished! Hopefully your replacement alternator will hold up for a long time to come. If you want to be able to monitor the health of your charging system, I would recommend getting an Autometer Voltmeter gauge, or similar product. Your charging system should be between 12.5 - 14.5 volts at all times (with some minor fluctuations). Usually when your alternator starts dying, you will start to notice that the voltage output will decrease. This will give you an advanced warning that something needs to be fixed, and prevent you from getting stranded somewhere inconvenient in the future.
Tools Needed:
Jack and jackstands
Pry bar
Hammer
