1 - 11 of 11 Posts
G
I'm new to the forum......I am in the process of a swap which includes a hydro Type R tranny, i don't want to use a hasport conversion!!!! can i use a pedal set from doner? i've read i can use 98-99 civic or teg with some mods. Now is the time car is completely gutted. Any helpl is appreciated
G
Because i'm doing a complete swap B20z/vtec, nothing is left in the engine bay wires which are going to be tucked so i am going to need to either do a hasport type mount or a complete change over to a donor hydro setup. The only part that seems difficult is the pedal end of the swap. Tilton offers a sweet setup http://www.tiltonracing.com/content.php ... id=214&m=d for about $400 for a complete kit, but i'm trying for an old school approach (also i'm being cheap) Money saved on the clutch conversion more for pistons and other goodies. the only swap I have read done was using 98 teg setup and it wasn't very informative
G
The plumbing is the easy part, not much difference than fuel or brakes lines and although fittings could be a hassle, but I still need the major components pedals master clutch cylinder and clutch slave cylinder. I really need a donor car!!
its probably going to be more hassle than its worth to do a whole hydro swap.
I would just use the hasport kit, and if the cable is a big deal maybe run it under the intake manifold?
if your set on it though I have a 92 prelude pedal set up, not sure it will work for you but if it can Ill make you a deal on it 8)
G
Discussion Starter · #8 ·
I read there are problems with the hasport hydro conversion, not many but enough to proceed with caution and I'm set on doing it. Why not I just rise to a challenge and who knows maybe it not as hard as some people make it out to be. As far as the lude pedals I don't know, I was hoping someone out there had more infor
G
Discussion Starter · #9 ·
Any 92+ civic off the junkyard will be a fine donor.
Delsols, integra's etc will be fine too.
Since you're "building" anyway you could get one of those nifty omnipower clutch cylinder assemblies.
Sorry missed your reply!!! do you have a website for omnipower??
1 - 11 of 11 Posts
