OK, well, maybe not literaly. I finaly got my engine back together, and with some timing changes, got it to run. But there are problems. Before it ran ok, it would turn over, and gurgle, then die. Now it runs ok, i took it for a quick drive up my street and it stalled once. The only problem is that there it white smoke comming out of the engine. I can see it in the front by the header and it is also in my valve train if i take the cover off. Its also comming out of the exhause pipe like none other. Its really worying me. I will be trying agin tomorrow and buying a compresson tester. I replaced the piston rings, could that be the problem. Any help would be appreciated.
