I just figured out why my car started suddenly dying. Apparently, there is something wrong with the contacts in the switch cylinder. It works on "Start" but when you let go so it goes to the "On", power is cut off and the car dies. The speedo actually drops to zero and my doors unlock (actuated by the alarm system). If I hold the key somewhere just a bit less than "Start" but more than "On", the car runs. Of course, this means I have to be hunched over holding the key in this painful position while my wife shifts the car for me. Not a long term solution.
I looked at the Helms, and it looks like I have the following options:
1) Try hotwiring the switch at the harness below.
2) Remove the lower dash and column cover to replace the cylinder and/or switch with the same from my spare rex.
So has anyone dealt with this?
