will a 5speed transmission from a 1.5L 1987 crx dx fit/work on a 1990 1.6L crx dx? thanks
sort of...the only transmission he needs to worry about is the 88...89-91 transmissions will work with each other since they all have the same spline count...dohcrxl said:No it wont. You need an L3 tranny from an 88-91 crx/civic/hatch to bolt onto the engine.
There's more - you need to get the right year tranny to match your clutch or the spline counts on the disc and input shaft wont match or mesh.
