Im getting ready for the Florida meet but I need to stiffen up the susspension a bit.
I forget, higher number is softer or the other way around?
So, it seems to me that the higher numbers are stiffer.Lowest setting is 15% softer than stock OE and the highest setting is 40% firmer than stock OE.
you need stiffer spring rates.. those yellow Ractive coilovers arent good. Get a better setup. That suspension came with the car when I bought it..unfortunatly.scramblerman said:Thanks guys![]()
