I would think there is a vacuum leak somewhere. Its not the booster since it works fine without the ac. Its it only at an idle? Does the idle boost come on?TheEmrys said:
I would think there is a vacuum leak somewhere. Its not the booster since it works fine without the ac. Its it only at an idle? Does the idle boost come on?TheEmrys said:I just had an odd little problem. With the A/C on, I lose a good portion of my brakes. It seems like I either have a problem with my A/C or my brakes. My first thought is my brake vacuum booster is having issues keeping up with the amount of vacuum needed when the A/C is running. Anyone else have any thoughts? I'm ready to hit the auto-parts store and replace it, but if anyone else has had any other ideas, I'd like to hear them.
I just dont get it, because even if the booster does not work at all, you still have brake, just harder to push. Maybe its because you need more force with the ac on due to the throttle boost with ac. I bet its your master cylinder. If you need tip on how bleed it/install, let me know. It's really easy. Cost me 10 bucks more for a new one compared to rebuilt at NAPA.TheEmrys said:Anytime the A/C is off, I have full brakes. With the A/C on, my foot goes almost to the floor, but braking does occur. But, I can pump the pedal with the A/C on and get better braking, and my foot goes to the floor much more slowly.
