- Losing 1 - 2 qts per fill-up.
- No noticeable oil leaks on engine or underneath car
- No exh smoke
- Starts fine
- 1/4 spark plugs was oily when removed
- 175K miles on car
- Pretty thick layer of soot in tail pipe and exhaust is aftermarket
- Replaced PCV
- Compression seemed ok but maybe I'm doing it wrong.... it's been a while
o disconnected distributor
o I cranked the engine about five revs for each cylinder.
o Readings were all 180 after five revs and I noticed that pressure continued to build beyond 5 revs
At this point, I'm open to any theories on where the oil is going, or what I've failed to check
