so i'm almost 100% sure i'm going to go all motor ls-vtec. so here is the list of everything going into it let me know if i'm missing anything (anything i want a 100% list of everthing i need including the swap parts) oh and i'm wondering if i need to bore and sleeve if i want to make upwards of 230 hp.
b18 block
crank balanced knife edged
pct (ctr) piston
eagle H beam rods
(i dont' know what brand) heavy duty rod bolts
(i don't know what type of HG) high compression head gasket
arp head studs
golden eagle oil feed kit
B16a head
P&P
possibly buddy club spec V cams
" " valves
valve guides
retainers
springs
5 angle valve grind
ITR intake manifold
Hondata intake manifold gasket
ITR LMA
ITR oil pump
ITR timing belt
ITR water pump
obd1 b16 ecu
obd1 tune (don't know what to use)
accesories
AEM C.A.I.
Dc-sports header
invidia cat back
ngk spark plugs
b16 lsd cable tranny
exedy organic clutch
fidanza lightweight fly wheel
motor mounts
half shaft
axles
b18 block
pct (ctr) piston
eagle H beam rods
arp head studs
B16a head
P&P
" " valves
valve guides
retainers
springs
5 angle valve grind
ITR intake manifold
ITR LMA
ITR oil pump
ITR timing belt
ITR water pump
obd1 b16 ecu
accesories
AEM C.A.I.
Dc-sports header
invidia cat back
ngk spark plugs
motor mounts
half shaft
axles
