1 - 6 of 6 Posts
I'm in the middle of my swap, and have run into a major problem... I don't know what clutch kit to get. I was told that a clutch kit for a VTEC del Sol would fit, but the Exedy clutch kit I got off eBay does not match up.
A few differences:
>The pressure plate and flywheel only use six bolts to mount together (should be nine??)
>The throwout bearing included in the kit is totally wrong
>The clutch disc splines are larger than the input shaft splines
The only thing I can think of being the reason is the Y1 tranny... LSD must be different from the non LSD trans.
What can I do? Just find a clutch disc that fits correctly and run the old throwout bearing and only 6 pressure plate bolts?
Anyone else used an Exedy clutch kit successfully?
the delsol uses a hydraulic clutch set up. which uses a different throwout bearing. so you need a different disk and a throwout bearing for a 90-91 teg.
1 - 6 of 6 Posts
