Main Relay Repair help
1332 Views 3 Replies 3 Participants Last post by  mithuth
Does anyone have a pic of what part of the main relay I need to solder? I am going to rip out the main relay in -10 degree weather, and try to solder it in the garage so I can drive the car home.
Also, will the car pop start and run if the main relay is bad?
1 - 4 of 4 Posts
http://www.tegger.com/hondafaq/mainrelayoperation/badmainrelay.html
See the little discontinuity in the otherwise smooth surface of the solder around the pin? That's the crack in the joint. All you really need to do is heat it up with an iron until the solder flows again. If you want it to last, put some more solder on it as well. You can see how the one that failed has less solder than some of the others on the same board.
FWIW I had to fix this same problem on a power supply board in my oven, it seems to be a pretty common failure in circuit boards of this type.
It shouldn't, No fuel pressure.
Thanks guys.
Now to go freeze my bum off in this -10 weather and try to get it out for repair.
1 - 4 of 4 Posts
