If you swap your motor in California you need to have in inspected by a state referee. You will need to e-mail the following before your visit (copied and pasted from referee e-mail).
Once you have all of the above you schedule an appointment by going to asktheref.org and calling the phone number provided.
Once they verify via e-mail you've provided all the necessary pictures you're cleared and can now schedule an in person visit.
Once youre there, the referee will do a visual inspection to make sure all the wiring and all sensors are legit. He will ask to see the ECU and take pictures of the vehicle. He will then do an evap test to check for leaks (make sure all your hoses are properly connected). He will then turn the key and inspect the lights on your dash. He will then turn on the vehicle and check the timing and make sure your radiator fan turns on via fan switch (if you have your fan hooked up to a toggle you wil FAIL).
Afterwards, he will tie down the vehicle and and begin the smog process. I believe its 15mph on 2nd gear and 25mph on 3rd gear. He will shut the vehicle off, go back to his computer, type some notes, print out the label and stick it in your door jamb area.
The info is automatically sent to the DMV and you can finally register the vehicle. For future smogs you can go to any smog station just show them the label. Good luck.
- Vehicle Registration
- Donor vehicle VIN
- Picture of the front of the vehicle with the hood closed.
- Pictures of the exhaust showing location of the catalytic converter and oxygen sensor.
- Two pictures of engine compartment
- Picture of the engine control module part number
- Picture of the engine code
