1 - 5 of 5 Posts
fit yes
work no
like Jmart said... if the 1.5 has been converted to MPFI then it will work...
if it is still the stock DPFi then no it will not work... you need another dpfi 1.5 dizzy.... let me know if you need one I have one for sale cheap.. . PM me
Chris
Actually, it would work if you fiddled with the wiring a bit.
I would be inclined to agree with paul
although there is probably no one that has
ever tried it..
The distributors are basically the same thing
except the MPFI version has an extra sensor to
trigger the injector pulse..
So if you were to hook up the five out of the seven wires
in the appropriate configuration,It should work..
If the extra sensor is not hooked up,It should not matter.
1 - 5 of 5 Posts
