My crx leaks from the hatch struts when it rains dont know whats wrong the seals for the hatch are still good its leaking right where the struts bolt on to the interior body. what can be the problem?
I used por15 but any silicone or even some more seam sealer will work.jloehlein said:My CRX leaks as well, I can see water drops coming down the inside of the rear 1/4 windows, but I have a leak up front as well. I park the car facing uphill in my driveway and water pools by the change tray and fuse cover under the steering wheel in the dash.
How do you typically fix the broken roof seam sealer and clean out the sunroof drains?
