ok to start with my signals and hazards dont work,i check'd the fuse nothing happend,changed all the light with new ones nothing i think is the flasher relay(not realy shure)cuz the signal light switch got suck for a wile but it its fine now, i dont think thats it because the hazard button was fine but both things stopd working at the same time
another problem is my crx is giving me some problem starting up like it doesnt want to turn on but then it does, wen it reach's normal temperature it starts fine no problem,my guess at first was the engine timing was of(not were it should)but it starts perfectly when it reach's normal temp so now im guessing its got something to do with the fuel maybe the fuel filter not realy shure it can even be a fuel injector
i need help on this sorry that my english is bad if you dont understand it i will try to say it in another way thanks
