hey guys, i finally put in my b18 Ls swap today. Few things, its a '91 Crx Hf, its a b18a block, b18b head, b16 S1 tranny, running Obd0. I did the swap, etc. etc. started her up for the first time, fired right up, let it idle for a minute and it sounded great so i shut her down and put the rest of the swap together. I started it again in a bit, fired right up again, this time i let it run up to temp but i noticed it started getting hot pretty quick, lots of air bubbles coming out of the radiator and my fan did'nt want to turn on for some reason, which sensor controls the fan switch?? any how it got about 3/4 up the temp gauge so i shut her down for a while. i started it up again a bit later after it cool to adjust the clutch, it ran fine, adjusted the clutch but it got hot again so i shut it down again, still getting lots of bubbles out of radiator, not constant bubbles like a compression leak, just air bubbles in the system, more irregular. so i let it cool for about an hour or so. my buddy stops by to check it out, i fire it up, hit the gas to rev it and wham, it boggs, no power, it would idle but as soon as i go to hit the gas it would bogg, then it would just clean up and i could rev it fine all the sudden and it would have full power, then out of no where just bogg again and try to stall unless i let off the gas. Now i can't get it to run straight, it starts up fine and idles fine and i'll get a rev or two when i first start it that has full power and revs up fine but then it will just start bogging whenever i hit the gas again and actually stall out sometimes. i also noticed that when it starts bogging the tach gets a little twitchy, and expecially right before it stalls out. this leads me to believe bad dizzy off the top of my head but this dizzy seem to work fine in the car i took the motor out of, but i dunno, i never really ran the other car much. What do you guys think here, i'm really dissapointed that i could'nt get this thing perfect in 1 day, i need it to be perfect by tomorrow as its my daily driver and i need it for work monday.
i was also wondering, i have a perfectly good OBD0 d-series dizzy on my SOHC that i pulled in favor of the b18, whats the chance that the guts of the dizzy are interchangeable, basically can i take the ignitor and such from the Sohc dizzy and put it into the DOHC dizzy?
Also as for the car getting hot, i noticed that the lower radiator hose never gets hot, its cold even after the motor starts getting too hot, i have a new radiator, hoses, water pump, Thermostat, all new parts, think this could be caused by a massive air pocket in the system or maybe a faulty thermostat not openening, or is there any wrong way to instal a thermostat on these honda's???
Any help is appreciated, i really wanna get this thing running right tomorrow, i'm so pumped about it, but feeling a little let down right now so somebody help this situation please. thanx.
oh yeah and the car is showing no codes. i used the harness off my single cam obviously. the only wiring i changed was i extended the map sensor wires so they'd reach the TB mounted MAP, and extended the O2 sensor wire (did'nt have shielded wire so this is ok i believe). Also on the bad of the b18a block next to the oil filter there are 3 sensors, 1 is a regular looking plug i think maybe temp sensor, another 1 is a 1 prong sensor, don't know what it is but i plugged it in, but then there is another sensor that has the same type of male leads sticking off of it but has 2 instead of 1, there was nothing to plug into this, what is it, some sort of a knock sensor maybe?? thanx.
