I took a few photos of my CRX today and I figured I'd share....
Engine/drivetrain:
JDM B18C ('96 ITR)
Skunk2 Ultra Street intake manifold
Skunk2 Ultra Pro 68mm throttle body
Skunk2 fuel rail
Toda adjustable cam gears
PLM header (Toda replica)
Blackworks 2.5" test pipe
Fujitsubo Legalis R cat-back exhaust
Generic 3" intake tube, black-wrinkle powdercoated by Charlie Moua w/
BPI velocity stack w/ K&N cone filter w/Vibrant couplers
Moroso steel oil pan w/ baffles
Mishimoto oil sandwich plate adapter
Rywire tucked radiator w/ Deraille fans
Custom -16an radiator hoses from BMRS
K-Tuned -16an thermostat housing
K-Tuned -16an upper coolant housing with filler neck
Earls inline fuel filter
Earls AN fittings/hoses
Radium fuel pressure regulator
OEM transmission ('96 ITR with OEM LSD)
Exedy lightened flywheel
Exedy Stage 1 clutch
Hybrid Racing short shifter assembly
Hybrid Racing solid shifter bushings
Hybrid Racing 130R delrin shift knob
Skunk2 billet VTEC solenoid
HASport black engine mounts
HASport hydro conversion bracket (custom anodized black)
Spoon Sports radiator cap
OEM "vtec" valve cover, powdercoated matte blue by Charlie Moua
Custom pcv breather box with -10an hoses
JB Tuned pcv port block-off / AN fittings
Hondata Coil-On-Plug retrofit (with oem Honda coils)
Locash Racing billet distributor cap
Misc. hardware from Downstar
310 / Hush Performance billet hood hinges
Sol Kreations aluminum windshield cowl w/Downstar hardware
Chasing J's titanium oil cap
Chasing J's titanium dip stick
Chasing J's titanium valve cover hardware
Chasing J's titanium coil on plug adapter plate/bolts
Chasing J's titanium vtec solenoid cover/bolts
Chasing J's titanium exhaust manifold studs
Chasing J's titanium cam cap bolts
Chasing J's titanium distributor bolts
Suspension:
Koni yellow shocks
Ground Control "sleeve-overs" w/
Eibach springs (600f/550r)
Ground Control extended top hats (front & rear)
Innovative Pro-Series Competition traction bar
Skunk2 front lower control arms with spherical bearings
Special Projects Motorsports/Hardrace "Kiwi Edition" front upper control arms w/bronze bushings
Hardrace rear camber arms
Hardrace toe arms
Hardrace rear trailing arm bushings
Stock front lower control arms w/Mugen inner bushings, Energy Suspension poly shock bushings
Function 7 rear lower control arms
Neuspeed rear lower tie bar
Energy suspension poly sway bar bushings (front/rear)
Stock sway bars (front/rear)
Wheels/brakes:
SSR Type C wheels, 16x7 +35
Hancook Ventus RS3 tires, 205/45/16
Wilwood Dynapro calipers (front) w/11" rotors with
Wilwood BP-20 brake pads
Fastbrakes rear brake kit with DC Integra calipers & 11" rotors
Fastbrakes stainless steel brake lines (front/rear)
Prelude brake master cylinder
Motul RB600 brake fluid
ARP extended studs (front/rear)
Muteki HR38 lug nuts
10mm spacers (front)
15mm spacers (rear)
Exterior:
JDM/SiR (whatever you want to call it) front end
PasswordJDM J's Racing replica front lip (Fiberglass)
JDM tail lights
JDM sidemarker lights
USDM oem window visors
Shaved rear windshield squirter
Shaved rear wiper motor
Color-matched side mirrors
Special Projects Motorsports/PCI front splitter
Special Projects Motorsports/PCI side skirts (4")
PCI race wing
Gregparts antenna block-off
Interior:
OMP WRC steering wheel
Sparco steering wheel hub
Works Bell 30mm steering wheel spacer
Mugen pedals (replica)
Cobra Suzuka carbon/kevlar bucket seat (driver) w/
Cobra side mounts w/ custom seat bracket
Schroth Profi II - FE ASM 4-point harness
Autopower "Race" rollbar
88-91 Civic arm rest
JDM rear seat w/
JDM rear cargo cover
UKDM gauge cluster
OEM floormats
Gregparts block-off plates (radio, climate-control, clock, switches)
Element fire extinguisher
Electrical:
Rywire milspec engine harness
Rywire PDM chassis harness
Hondata S300 v3
ElectricLife aftermarket power windows
Defi "White Racer" oil pressure gauge
Defi "White Racer" water temperature gauge
Antigravity YTX 12-16 battery in custom battery mount
Engine/drivetrain:
JDM B18C ('96 ITR)
Skunk2 fuel rail
Suspension:
Koni yellow shocks
Hardrace toe arms
Wheels/brakes:
15mm spacers (rear)
Exterior:
JDM tail lights
PCI race wing
Interior:
JDM rear seat w/
UKDM gauge cluster
OEM floormats
Electrical:
Hondata S300 v3
