It does but can get tricky if you have AC, and a stock fan, things of that nature.downest said:A regular open ended wrench works fine.
To take it off just cut the wire and use a regular socket. That's the hardest part.ludesrv said:It does but can get tricky if you have AC, and a stock fan, things of that nature.downest said:A regular open ended wrench works fine.
The socket is 5$, and cuts the time down by half. Well worth it in my opinion!
That's fine for taking it off, but what about putting the new one on? You can't cut the wires then. I'm betting many of us don't have a deepwell 22mm socket laying around either... which means a trip to the store. Best to just use an O2 socket.drnknmnky13 said:To take it off just cut the wire and use a regular socket. That's the hardest part.
Fill the system with a 50/50 mix, idle the engine with the radiator cap open until the fan come on twice, all the while topping the radiator off as it sucks the coolant in to fill air pockets within the engine. After the fan comes on the second time, this should've been more than enough time to bleed/burp out the system. Top off and reinstall radiator cap. You're done.WannaBe said:I replaced the o2 sensor (don't go to NAPA to get an o2 socket - $25!!!) and i also replaced the thermostat. how do i properly bleed the cooling system? start the car and put anti-freeze into the radiator until i wont' take any more; putting in a little at a time? or is there a more effective way?
Baldy
