I am having a problem with hesitation on acceleration, as if the engine was turned off for a second, intermittantly since I have done my obd1 conversion. It occurs at full throttle only at about 3500-5000 rpms then, it runs up normal. I have swapped out more things then I care to list, and no change. Someone told me that my usdm dx needs to have a wire cut on my obd0 alternator (its from a obd0 b16a swap) and this might be responsible?
Anyone know if this is true or what wire I need to cut? BTW I used the Rywire harness for the conversion.
Thanks in advance
Thanks in advance
