Ok, so I'll leave the resistor box for now until I get some OBD1 injectors. My next question is about the VTEC... I just hook it up to the single wire coming out of the solenoid? There's another plug there that's identical to the coolant temp sensor plug under the dizzy, do I want to do anything with that or just leave it alone? Also, is the Y8 head supposed to have a coolant bleed valve? Mine has the spot where it would go, but the hole is blocked at the bottom and there aren't any threads. I suppose I could take the one off my A6 head if I really need it. Once I get the timing set right and run the thing off the PM6, I'm going to try the harness, hopefully I'll be running VTEC by the end of the day!
