As you can see, the Honda OEM is way beefier than the aftermarket version. Not only are the springs heavier duty, but the opening is substantially bigger.
Also, the OEM version has a little valve opening (circled below). It prevents backflow but allows a bit to always get through the top. Why is this important? I think it is because if you are trying to bleed the system, you can't really do it well with the aftermarket thermostat until it opens completelty. I think that little valve allows the air bubbles to pass through.
Now here's the side that fits into the block. The two red circles are tabs in the rubber to make sure that it fits with the valve at the top (even though I took the picture with it upside down). Again, you can see the difference in quality.
Now considering that an OEM thermostat is only $15 including rubber mounting ring, I think it is worth the extra cost.
