1 - 9 of 9 Posts
Also, my parking brake light does not go off when I take off the brake. The it is connected as it should be. Anyone have any bright ideas right off hand?
Thanks
Discussion Starter · #4 ·
Interesting, I did not know the dummy light signified low brake fluid too. Makes sense now that i remember plugging in those two wires to the reservoir.
Thanks guys, I'll go check and let ya know.
Whew! That reservoir was nearly empty. Filled it and sure enough, the light went out. But it makes me wonder... is the master cylinder leaking???
Must be rash of "low brake fluid" going on. The wife told me a couple of weeks ago that the "brake attention" light in the dash cluster on her DX was coming on once in a while. I checked the fluid level, and yup, it was low. Bought a fresh pint and topped both our CRX's off while I was at it.
Low brake fluid could also be caused by normal pad wear...but most likely not in this case if it was almost empty. I would first check the master cylinder for wetness or peeling paint, as brake fluid is not nice to paint. The second thing I would suggest is the flexible lines that go to your calipers... both of mine were cracked pretty badly, one even to the point where I went to stop at a red light and all of my brake fluid went out the crack in the hose rather than to the brakes. That was interesting. Lastly, I would check the rear wheel cylinders for leaks...they aren't too expensive and fairly easy to replace while doing rear brakes.
Discussion Starter · #9 ·
Ya, i did check already. I noticed when i got the car and pulled the engine that the paint on the bottom of the booster, below it on the rear crossmember all of the paint had peeled. I knew this was from fluid but chalked it up to someone stupidly spilling fluid. now I'm concerned that it might be a slow (or fast) leak. I'm going to put the mc, booster and calipers from my wrecked 91 Si on there eventually so it doesn't matter to much. i am however planning a road trip to Ohio in a week, so I'll carry some extra fluid with me and see how it goes.
Thanks for all the help.
1 - 9 of 9 Posts
