I decided to upgrade my ignition so I can do tuning on my b16. Got Rywire harnesses, Distrbutor King dizzy and 4 wire O2 sensor. I have a p28 that was modified to use with HOndata s200.
Driving around town, it works like a dream.
Took it to the Dyno, at full throttle only, at varing rpms, the engine has a dead pause then recoups and continues to rev all the way up. Its not a fart or a misfire, it's as if someone turned off the key. Tried a different ecu- the same. It does not look like the fuel pressure changes on my gauge, and I cannot prove that I lose spark, but things are going very fast at 5-7000 rpm's. Again, without getting on it, it runs fine until long rev up through gear, and then intermittantly at different rpms.
Anyone have this problem? Any thoughts? Could a bad relay switch do something like this? Even though dizzy is brand new, could this be the problem?
